I'm 36 hours into the sponge test prescribed Metal Magic treatment and, based on only the pool's steps, it looks like MM is working to remove stains. However, the white, chalky cloudiness in the pool is so bad that I can't say anything about the stains deeper in the pool, because I can't see more than the first step! It really makes me wonder if MM (acid) just works by simply by dissolving the surface plaster in the pool, which concerns me with this 25, 30 or perhaps even 40 year-old pool!
The white cloud formed the first night and it's not getting any better with 24/7 sand filtering and something like 18 hours per day of Aquabot (original model) roving and filtering. I've maintained the FC at recommended 1 ppm. CYA is now about 22 ppm. The previous owner left a bottle of EZ-Chlor Drop Out but TFP doesn't seem too keen on flocculants. Nonetheless, one MM user here reported good results with Leslies Alum, which is aluminum sulfate, and the liquid flocculants (aluminum chloride) like my EZ-Chlor might work just as well but, from what I read in TFP, they just speed up the filtering process and even the MM instructions say "ProTeam EXO Clarifier may help speed the recovery of cloudy water."
I've had good results in the past by putting 1/2 cup of DE into my skimmer and I tried it with the MM cloud yesterday. It does remove the "chalk" but, as before, the sand filter holds far less matter and requires frequent backwashing (about 50 gal. minimum per DE-backwash), which is hard to accept on a limited spring water supply that has to also feed a household and a garden and trees during this very dry summer.
Alternatively, the Aquabot's filter bag allegedly filters down to 2 micron so maybe I'll try cutting way back on running my 1.8kW pool pump after the 48 hour treatment mark and just run the more efficient Aquabot, which probably moves almost as much water as the pool pump. Plus, the Aquabot sucks the settling white particles right off the floor. Alternating periods of still water to let the particles settle with Aquabot cleaning might also be a good strategy, though I'm sure the Aquabot will stir up any settled sediment fairly readily.
