Separating Globrite lights
Turbo1Ton
1,995
NE Oklahoma
Pentair Intellichlor IC-40
So my PB put the 3 lights in the pool and the spa light on the same circuit. I would really like to separate them out. I have no good reason for it other than just because that's the way I want it. It looks to me that the only way to do this is to add a second low volt transformer for the spa light. I was trying to figure out a way to do this without having to do so, but I am not coming up with anything.
Has anyone done this and can confirm that adding a second transformer is the only way?
--Jeff
Correct. You need a separate transformer for each light circuit you want switched by your IntelliCenter. And I assume you have a high voltage relay available.
Reactions: Turbo1Ton
