Sensor Error on a Raypak RP2100, my understanding is this is caused by a 2 degree difference,
I've seen where disconnecting the sensor (power off) for 5 minutes will clear the error,
I tried that and it did not correct the error - however, I pulled the sensor (side of heater) and reseated it,
and also depressed the SW1 switch on the board - this seems to have corrected the issue but I'm trying to
verify what the function of the SW1 switch is? Any insight?
