Seem to be using A LOT of chlorine
Good.
I assume your CYA test above is a recent test. I would suggest you raise the CYA to 80 ppm when you start the SWCG.
We do lose CYA in our pools in June, July, and August due to extreme sun. I lose up to 15 ppm CYA a month. So be aware your CYA can drop some. But sounds like you have a high natural consumption of chlorine. It should go down with a higher CYA.
Be aware of degraded liquid chlorine. The heat here can effect it rapidly if it is stored outside. Source product that is either extremely fresh or stored inside.
Reactions: Pwickens
