So, kinda last minute I decided I wanted to add a pair of deck jets to my new pool design. My PB suggested if I was going to add two, why not four as the plumbing would already be in place and the additional jets would add very little to the price? One thing led to another and now I am going to have 4 deck jets, a dedicated wall suction in the pool, and a high flow return to my spa floor so I can operate the spillway without the added noise and water turbulence of running the spa jets. This is all to be run on it's own separate plumbing by a (I'm assuming Pentair) VST pump.
In the forum reading I've done, I've noticed that different types of pumps are usually recommended depending on whether the goal is high flow (spillway) or high pressure (deck jets). So my question is, is a VST pump the correct choice to run both of these types of water features? Individually and/or at the same time? The deck jets are rated at 4.5gpm and 16' of head each. The spillway is a sloped negative edge and is going to be approximately 6' wide so (I'm assuming) about 60gpm and unknown head on the return line feeding it.
