jsf0656
jsf0656 said:ladylion said:jsf065 - great job! This is the next thing I aspire to do, prefering the sprinkler outside the pool too. Quick question, why put the ball valve below the standard return? Wouldn't putting it above the return before the sprinkler head allow you to turn off the sprinkler when you don't want it and let the normal return function, or am I missing something? Seems like you have enough pressure from the picture to run both at the same time. Another question, why the small adapter above the ball valve before the T? I'm trying to learn as much as I can so I only have to build one for mine one time, so thanks for patience with my stupidity. Thanks !
i wasnt using the original suction port at all. since installing the skimmer, i decided to use the old return as a dedicated sprinkler. the intex pump provided plenty of power to use them separately. plus i run the skimmer all the time. it keeps the pool very clean! i used a short adapter that i had to lenghten out the connection rather than buying another piece of pipe and cutting it to fit.
there are no stupid questions! i learned everything about a pool right here on this forum. you could have used a single piece of pipe but chose to use a part that i already had to acomplish the same thing.
