I've been wondering about something for a year, but never called the PB back to get clarification. So here is the info - which will lead back to the title of the thread about the second hole at the bottom of the skimmer. The pool was built last summer with completion at the end of July 2015. The builder sold us on one of the things they did was to install two separate suction lines for the main returns. It's listed on the contract. This would help prevent any problems down the road should one become clogged - I don't remember the whole story now, it sounded good at the time and I'm no pool expert. I have hundreds of pictures during the build (I may go back and put a build thread together) with the exception of the main plumbing lines around the pool. I was out of town the day they did the plumbing and it was all covered back up by the time I got back home.
Move along a few weeks, pool is done, start up day comes and PB start up guy comes out. One of the first thing he does is take a plug out of the bottom of each skimmer - one was already open and connected to plumbing - the other - after the took the plug out - just has dirt under it. I have pictures confirming there is no plumbing connected to the second hole and you can feel - it is dirt - open to the ground under it at the bottom of the skimmer. Is this normal? If I'd truly had 2 separate suction lines plumbed should one of them have been connected to the second outlet on the skimmer or would the dual line only be for the main drains?
The pic of the skimmer - the hole on the right you can see debris and the hole on the left is plumbed - I know it is dirty right now anyway.
Thanks for any insight.
