Hello to Fellow TFP's BBB method buddies Thank you for everything and supporting us in our 8th year now! Again this year opened up to a green pool . Not as bad as last year, but the same thing happened-The cover fell into the pool over the winter without us noticing for awhile with all the nastiness and water on it! Bad Luck I guess. So here we are again. It doesn't look as bad as last year, but oh boy you need patience with algae for sure.
My question is :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: Should we scrub the sliminess-sides and bottom to loosen up before we put the bleach in? I am also putting CYA in cuz it was not reading any (or less than 30) Just put everything in at once? Bring to a 12? I forget?
We are turning the pump right now. There wasn't much debris in it. We either scrub now, or not for another 24 hours to start.
