ScreenLogic schedule
e,
Try setting it for 8 am until 8 am... and see what happens...
Also, just to make sure... You can only have 12 total schedules/egg timers/ run once settings IF you have a full up EasyTouch. If you have an ET lite, with no load center, you only have 4... The problem with ScreenLogic is that it will allow you to enter all the schedules you want and won't tell you that you are over your max limit..
Also, if you are in the habit of turning the pump on/off using the Pump/Filter button, depending on when you do, it can screw up the schedule and it won't get back on schedule for 24 hours..
And.. you don't schedule the pump, your schedule should be for the "Pool circuit" and you need to make sure that the Pool circuit has a "speed" (like 1200 RPM) assigned to it..
Thanks for posting,
