Screen logic control shows water feature on when its off and vice versa
hartpump
53
Clinton, Ohio
Hello pool gurus. I did a search on the site but didn't see this exact issue with these systems. My issue is that at some point last year the valve that controls the water feature shows as on when its off and off when it is on. The valve works as it is supposed to, and there is flow to the fountain jets. I appreciate any thoughts on this one. Both the app and the main control panel show this situation.
Chris,
The EasyTouch has no clue where the valve is... It just knows to move it 180 degrees when it it is told to do so..
You must tell the EasyTouch what is the on position and what is the off position. You do that with the little 3-way toggle switch that JamesW shows above.
The Switch is On - Off - On.. Just move the toggle to the opposite On position and your problem will go away.
