Scale on marbelite pool
Welcome to TFP.
If it is smooth it is probably not scale. Scale is usually rough from calcium deposits.
What is your water chemistry?
How do you chlorinate your pool?
What test kit do you use?
Post your water chemistry:
FC
CC
pH
TA
CH
CYA
WATER TEMPERATURE
CSI (calculated by PoolMath)
Things to read:
Hi water chemistry using liquid test kit
Ph 7.6
Chlorine 3ppm
Alkalinity 120
Chlorinated using hth floater+
A solar heating system was added to the pool recently but the problem occured before that. Not sure of exact temperature.
Ph 7.6
Chlorine 3ppm
Alkalinity 120
What liquid test kit?
We need all the chemicals I listed above to determine if your water chemistry is causing your problems.
