When CYA is put in a sock in the skimmer, we recommend that you keep the pump running 24/7 until its dissolved. The reason is that if the pump is off and water isn't moving, the water in the skimmer becomes very acidic from the CYA. Then you turn the pump on that big acidic bolus of water could be damaging to gaskets and such as it hits the pump and equipment.
Just a heads up-
Maddie
Just a heads up-
Maddie
