Scale Buildup on Sidewall Above Water Line
Sep 4, 2013
1
Central Texas
Fiberglass
Hayward Aqua Rite (T-3)
I had this fiberglass (SWG) pool for about 10 years. I've never been able to prevent this much less remove it. Any advice? The pH runs high since it's a SWG and our water out here is basic to begin with. Any help would be appriciated.
If that is only above the waterline, you might try manually buffing it out with a rubbing/polishing compound. If that doesn't work, try using other products going from very fine to a little rougher. You could try a Magic Eraser, then perhaps 1500 grit wet/dry sandpaper and work your way to a more aggressive grit (i.e. 800 grit) if needed. Anything above the waterline might show tiny imperfections or scratches once it dries, so always do a test area first to ensure you are pleased with it. Even if you do see tiny/fine haziness once it dries, going back over it with a polishing compound should help.
