Hi folks. I had my pool replastered with Wet Edge pebble finish a few weeks ago. I thought I had finally got all my of chemistry values right where I wanted them. Readings from today:
FC=8
TC=8
PH=7.4
CH=260
TA=80
CYA=30
So everything is within the recommended ranges. But, I just used Taylor's water balance calculator (the fun little wheel that comes with the test kit), and with these values and a pool temp of about 70 degrees F, the saturation index is -0.25. It says -0.3 or lower is corrosive. Is a SI of 0 best, or are you okay as long as you are within the range of -0.3 to 0.5?
Are there any parameters I should adjust to get it closer to zero? Assuming I want to stay at PH of 7.4 and I can't change the water temp, I gather that I would have to raise CH and TA.
Also, I read somewhere online that for exposed aggregate pools, ideal CH is between 200 and 250 (lower end of range). Anyone ever heard of that? Is that right?
FC=8
TC=8
PH=7.4
CH=260
TA=80
CYA=30
