This spring my pool service company installed a PerfomMax 940. I had understood the technician to say that he recommended this brand because, in this system, water entered from the bottom and did not submerse the tabs all at once and that the dial would control the water level in the canister.
Is this the case?
I ask because even with the dial turned all the way off, the pool is rapidly overchlorinated. Most of the time when I open the canister it is filled with water.
A couple times it was not and at those times the tabs at top were not under water.
I’ve checked the manual and online for answers.
The O-ring is, or was secure - lately it keeps falling into the canister when I open it so I ordered a new one.
The air relief knob at top is secure.
The pressure relief valve look good.
I run the pump as low as I can get it and still get my floor jets to operate.
When I emailed the pool service company they now say that I am mistaken - that the canister should always be filled with water.
Can anyone please tell me how the water flow should work when set to zero, and how I can get this thing to properly chlorinate my pool?
Thanks
Is this the case?
Thanks
