Saniclear 20 & Hayward
Aug 26, 2015
1
Oakbank,mb
Hello all...
Just thought I would post some info I found out today...
My Jaccuzzi Saniclear 20 cell died (after 2 years)and I decided to replace the entire system with a Hayward Aqua Rite with the T15 cell...
(I have had some problems with the saniclear motherboard too, the build and component quality is just not as good as the Hayward)
So these seem similar and they are..
- the Saniclear cell and the Hayward cell have the same dimensions (length and threads)
- this means the Hayward GLX cell cleaning stand will work with the saniclear cell
- i would assume the Hayward bypass would work as well and the hayward fittings would be suitable replacement if you broke a nut..
- the flow meter is the same ( same plug and connection )
Swap out was pretty simple... took about 20 min...
hope this helps..
Rob
