What about removing the pool and pouring a concrete slab. I know cost might be a consideration. First year I put about 3" of sand under one end of the pool to level it and it washed out. I took the pool down and scraped the high end to the low end and tamped it no more sand. Then added a tarp, 1 1/2" styrofoam board, and another tarp. I use a battery leaf blower to clean between each tarp and foam board, then over the last tarp before the liner went down. I would have poured a pad if the slope had been more.
In fact the instructions that came with the pool said no sand base, but I listened to a contractor friend who said sand would work fine. He is also the one who help scrape the ground to level it the second year.
So far the pool has been stable this year.
