I have an inground pool with a Pentair Sand Dollar filter. I recently had some sand getting into the pool, so I called a service tech. He recommended changing the sand, as it is 4 years old and I run the filter all winter. I ordered a new stand pipe and laterals. The tech emptied the sand, and put in the new stand pipe and laterals, inspected the valve and gaskets, replaced sand. This was an experienced pool tech I have used before. For a couple weeks I was getting a small amount of white very fine sand accumulating on the bottom. I ran my robot vacuum every 3 - 4 days and got about 2/3 cup of pure white very fine sand. To try and address this, I backwashed and rinsed last night. When I restarted the filter, it dumped several pounds of larger grain brownish sand back into the pool (this looked like the bags of new sand he added). Any ideas what might be causing this? Perhaps the priming flow rate is too high on restart? Too much sand, although we put in 350 lbs as the data plate says? Not sure what to try next.
