I took the pool cover off today. I started the pump and I'm confident I'm getting sand coming out of the return, so I've either got a broken lateral or something wrong with the valve on the filter. I'm going to try and get the filter open tonight so I can look at it and maybe get parts tomorrow. Some questions I have
Is there any reason I can't save the sand?
Will running the pump with the filter in bypass mode help to circulate the water for balancing - chlorine, pH, etc? the water is green right now. I'd like to at least try to start treating it so I dont have a bigger mess.
Is there an easy way to get the sand out, other than dumping it?
I assume I didn't get the filter drained properly last fall and it froze and cracked something. Can I blow it out with a shop vac or similar in the fall?
