I have 25 year old in ground pool (~30k gallons). Current filter is sta-rite (30 inch model with 400lbs of sand) has been in place for these 25 years. I bought the house 4 years ago and the last owner told me he replaced the sand in 2007 (he could not generate a receipt or any paper work thou).
Pool was closed for all of winters (Seattle) as a pipe burst. Pipe was fixed in May of this year but the water is not clearing up all (I even emptied the pool and refilled it with fresh water (70% water was replaced) but it will just not clear up0. My pool guy changed the 'O' rings in the old brass valve but that did not help either. It is now coming down to the filter itself.
Please help me with following:
Fix things:
- Replace sand in sand filter (~ $800/)
- Change valve to new multiport ( ~ $600/)
Replace things (needs new plumbing around the motor):
- Change every thing and replace with a new commercial quality sand filter with 600lbs of sand (~ $2500/)
- Change everything but replace with a smaller sand filter with 300lbs of sand (~ $1600)
Also, could there be anything else wrong with the pool system. changing all of this will clear up the pool for sure?
Pool is in very inaccessible area under the stairs (inside garage) as such labor involved is higher, + this is Seattle so you may more for everything here
Fix things:
