Hi Everyone.
I have been doing some research on my pressure of my filter as well as the flow rate.
My plan is to find a way to monitor the following 3 things
I am building a bit of an IOT system so I have a pressure sensor on my MPV and it alerts me when the filter is 8 PSI above the normal that I set i.e. it will trigger at 28PSI if I have the base set at 20PSI
Could I use a flow meter before(or after?) the pump to see if any of the weir's are clogged? or maybe even pressure sensors instead of flow meters?
Would a clogged weir not then effectively cancel out the pressure increase of a dirty filter?
Thanks
- Pressure of the filter (at the MPV)
- "Fullness/Dirtiness" of the Weir basket
- "Fullness/Dirtiness" of the pump internal basket
Thanks
