- May 22, 2023
- 41
- Vinyl
- Hayward Aqua Rite Pro (T-15)
Morning, I have a Hayward sand filer with a multivalve SP0714G11M. This is one with the spider gasket that is molded to the key. I noticed that in recirculate the filter was shooting water out of the backwash port, and that the pressure was reduced on the return side. I found that the most likely cause was the spider gasket though the filer is about 3 years old. Opened it up and looked okay but had some wear, so I ordered the entire top fixture from Inyo since I didn't want to deal with hammering out a handle and stuff. I installed it and it's still leaking from the backwash though be it less than before. I is keyed correctly on the notch and the filter itself is free of junk though I'll open and really scrub it later. By leaking I mean about 3 gallons a min flowing out the backwash. Can anyone confirm that the inside of the multivalve XL is supposed top have an angular stub that aligns with the central handle and that this isn't broken? The filter is level there is no notable debris in there and the gasket is new. Pressure is in the rated range at 18-22 PSI, any ideas other than the housing is afflicted by some kind of pool ghosts?
Thanks in advance
Thanks in advance
