Hey guys, first time poster, long time lurker
I have a commercial account with seven TR-140C sand filters, and they want me to change the sand in all seven. I told them sand doesn't need to be changed unless it's fouled up somehow, but they have deep pockets and they want it done. I'm looking for ways to save time and energy (and my back), so I thought I'd ask for suggestions from the best pool guys out there!
The pump room is crowded and it's very difficult to get a wheelbarrow in there, but they are providing a dumpster nearby for the old sand. There's room for a shopvac, but that will take forever. I plan to try a special rig that connects to my pressure washer wand, and it uses a venturi action similar to a leafbagger to "suck" the sand into a discharge hose. I've had limited success with it in the past, mostly because it works best with a sand slurry that's at least 50% water.
Has anyone tried to use a trash pump to remove sand in filters? I expect it would need lots of water, so hypothetically I could run the pump to fill the tank? They have vsp pumps, so hypothetically I could adjust the flow rate to match the vacuum rate. They dumpster would be about 50' away, so hypothetically I could run the discharge hose directly into the dumpster, no wheelbarrow required. Hypothetically, am I insane?
