- Jun 12, 2016
- 323
- Vinyl
- Intex Krystal Clear
I may of had it backwards I’ll look. I have it hooked up after output of sand filter and then to return.
So I did have it backwards but doesn’t seem to matter as far as pressure. Air is bled out.Do u have it going from the outlet of the filter to the swg then to the return jet of the pool? There are arrows on the swg indicating flow direction. If it’s backwards the flow switch flap will impede water flow.
Also did u bleed the system of air? You may need to do this multiple times if you didn’t fill the sand filter 1/2 way with water before putting in the sand.
I have a 1.5hp standard above ground pool pump & a 200# sand filter & never had a flow/pressure issue running the intex swg’s.
As soon as it’s hooked up running or not the pressure goes borderline yellow.
I have Intex 3000 gph sand filter
