- Oct 9, 2024
- 18
- Fiberglass
- Pentair Intellichlor IC-40
Ok, then that probably puts us around the 3-4ppm/day due to UV, which would be a little over 0.1ppm, so based off calculations, we'd probably need the SWG running at 100% for 5 hours to get the FC to 3ppm...which I'm guessing that we could safely be swimming in a little over 3 hours, since the FC should be over 2ppm.Typical chlorine consumption due to the suns UV is 2-4 ppm/day. Depends on your CYA level.
