Hello,
I know this subject has come up many times, I have searched the forums all over but have never found a definitive and conclusive answer.
I'm going to be adding a saltwater chlorine generator to my inground 10,000G pool this summer. My setup is very basic, I have a 1.65HP Jandy vs florpro pump and I am thinking about purchasing the Hayward Aqua rite salt generator.
After reading multiple forums I realize that redundancies are very important to avoid any explosions. Thus, my plan is to have the VSP on the same breaker as the saltwater generator and to run the VSP 24/7. The second redundancy would be the flow switch included with the salt generator. The problem is, I run my VSP at a reduced RPM for 12 hours and medium speed for the other 12 hours. Will running it at a slow speed add dangerous gases to the system?
Is there a better way to setup these two systems together? Also, on the Hayward Aqua Rite manual is says not to connect it to a timer, yet many people have the same system and have it connected to a timer. Does any one have any suggestions?
Agostino
Agostino
