Hi, I just bought a Saltron Mini and the manual says to shock the water with chlorine shock.
I cannot find chlorine shock for spa, but found salt water chlorine shock for swimming pool. Can I use that on freshly filled spa? It says that the free chlorine should be around 3ppm and to reach it with the shock treatment if I understand correctly.
Can I just put chlorine tabs in the float distributor and wait until it reach 3ppm instead of using the chlorine shock?
Or is using a chlorine shock for pool is the best way to reach the initial level of chlorine before starting using the mini ?
Thanks !
Thanks !
