Our pool was installed in 2012, and the Hayward T-Cell15 finally died this year. I purchased a replacement cell and installed it myself.
After installing it I was looking through information about the cell from Hayward. The documentation stated that if the cell is installed horizontally and using a VSP pump running on a slower speed there was a risk of the cell not completely filling with water leaving some plates above the water line. Our original cell was installed in a horizontal position with the offset facing up. Given that for all those years it generated plenty of chlorine I have to assume that even when running the pump at a relatively slow 1380 rpm it was being filled with water.
As a precaution I have rotated the cell 180° so that the offset is now below the incoming and outgoing pipes.
What do you experts say? Is it a good idea, bad idea or doesn't make any difference.
