Ideally you should test the FC and pH daily. You will likely find that the pH rises faster and needs more adjustment.
Once you get the FC level stable, you can get away with testing less often.
You might want to test the salt every month or so, depends on the amount of rain you get, splashout, or water you pump while backwashings.
Please add your pool and equipment information in your signature as it will help us help you.
