- Sep 23, 2015
- 2,012
- Plaster
- Astral Viron V25
Hi Mgxzen, when did you buy your kit? Mines about two months old max, I tested my very new 20,000 litre pool which as far as I know had three 20kg bags of salt at new fill in September last year( i remember them), I added another 20kg bag based on shop test two months ago, just before I knew about TFP, after that my CCL test was off the charts at 8000ppm. It didn't add up. I then tested the 4000ppm sample supplied by CCL and it was 5300ppm using a smart stir so I pretty confident in that test, my salt reagents are now exhausted BTW after testing and draining pool water. Two things I learnt I think, my salt was high but not that high and the test is faulty by about a third too high. I've email CCL with no reply which is disappointing.
Did either yourself or @mgxzen notice a difference in drop sizes between the two reagents? I believe there may be an issue with the tips making the drops too small on the reagent 3 bottle. Carefully swapping the tips may solve the issue but you need to be very careful. The reagents are very low volume and you don’t want to contaminate either with the other. Rinse in clear ammonia (if you have it), then distilled water and air dry in the sun. Be careful of the reagent 3, silver nitrate stain anything it comes in contact with. Use gloves and eye protection. And be very careful to remember which tip is which, rinse them separately, one at a time.
After swapping the yellowish detection indicator reagent 2, potassium chromate, will dispense a lower volume but it’s not that critical. An extra drop will help.
