Hi! So - I had my SWG system installed 2 days ago. I specifically told the pool guy to check salt levels before adding salt to make sure we dose it correctly. Of course, he didn't do that. My salt is reading 4150. I went in yesterday and could definitely taste the salt. The instruction book says the optimal level is 3500 - so I guess in reality 4150 is not that far off the mark. In any case, brought it up to the pool guy and his recommendation is to add water for 15 or 20 minutes per day until the salt level goes down. He also pointed to the upcoming rain as also helping. My question though is that I thought the only real way to lower salt is to drain some of the water from the pool and then refill with fresh water. Just refilling doesn't seem like it would help unless I refill to the point that the extra water is draining in the overflow vent? Thoughts? If I lower to 3500 - do you all think that I will still be able to taste salt or should I go a little lower like 3250?
