- Mar 23, 2019
- 87
- Plaster
- Jandy Aquapure 1400
Recently opened a new pool. We had “pool school” with the builder 2 weeks ago. He installed our SWG and added 400 lbs of salt the same day.
I’ve been taking readings a few times a week since and my salt level is in the 4600-5000 range (wide range is probably because I’m still new at this, using Taylor salt test).
The SWG says my salt level is 4850.
Is this an issue? Will the levels go down over time, or do I need to do a drain and fill per piol math?
Readings from today:
FC: 4
CC: 0
TA: 100
PH: 8.0
CH: 375
CYA: 45
Thanks!
FC: 4
CC: 0
TA: 100
PH: 8.0
CH: 375
CYA: 45
Thanks!
