Long time Pool Owner - First time to TFP site!!
Tandy Ei Aquapure cell just started flashing NO FLOW on the board. I saw this youtube video (Zodiac Jandy Ei Aquapure salt system quick fix on the cell - YouTube) that shows where the guy swapped out an old piece of plate and "revamped" it to fit. Then the NO FLOW indicator turned off. I have replaced my cell once due to a couple of burnt plates but several are still usable. I have it in my dead but not thrown out pool supplies. I'd LOVE to be able to use it so demonstrate to my lovely other half - "See....see...that's EXACTLY why I don't throw this "stuff" away!!"...but ...I digress. Can I take the old plates, cut them, and reinstall into the unit without electrocuting my 7 rambunctious grandchildren? Did this really fix the problem or just create others?
I stumbled on this site because this time of year, you can't find a pool guy even if you could afford one. So I started surfing. I read the thread on looking at the mother board and the daughter board to make the indicator go off. The pool is clean, filters clean, cell is clean and clearly shows water running through it. How does my single cell set up actually check the flow to see if it is low? My set up is just like the one in the video.
I haven't tried looking at the mother board or daughter board. Figured I'd leave the main unit un-opened for now. I tend to have extra parts laying around when I perform an electron surgery or normally the resulting autopsy.
May very well be time for a new cell or even a whole unit as this one is 8 years old and the cell replaced 4 years ago.
Any advice would be greatly appreciated....THANKS
