Pool was finished around 6 months ago and have been maintaining it myself following what I learned on the forum. For the first 1-2 months I did not install the salt cell and just used liquid chlorine. After I installed the cell I raised the CYA a tad ,added my salt, and all seemed well. I did start to notice I had to constantly add some CYA as the levels would seem to drop 20-30 per month. I attributed it to new pool and maybe not being able to read the CYA test very accurately. I do regularly visit Pinch and Leslies to compare to my test results. I use the tf100 kit with the stirrer (LOVE THAT THING) and I trust most of my results. I even purchased the pentair CYA test kit to see if it yielded better results. I now run the pentair kit and then pour the solution into the vial included in the TF100 to get a second look.
For the last several months I started noticing that the FC was dropping together with my CYA (even though running an IC60 cell at 100% 24hrs/day) and I started supplementing with liquid chlorine. I would add a gal here and there to bump it to around 5 but it would slowly drop (sometimes to 0) I thought it may he related to the CYA dropping and kept adding CYA. Originally liquid CYA but that got costly so switched to powder and i dissolved it in a sock inside the skimmer. The pool always looks crystal clear with no signs of algae or trouble. I run my pump 24/7 at around 28GPM and have a second pump that runs 24hrs circulating water through 2 bubblers at slow speed as well. I called pentair thinking the cell was going bad and they even changed it out but the tech stuck the old cell in a bucket with flow switch depressed and it created chlorine. Cell was clean and seemed to be working. It seems as it is related to my chemistry or something in the water causing the cell to not keep up as well as consume CYA. I do evaporate alot as the pump runs all day and i have a large spa with a long area of steady overflow but nothing that would indicate a leak (especially not to lose 20-30 CYA in a few weeks). What could cause a large enough chlorine consumption that the cell cannot keep up as well as drop CYA levels? When I add liquid chlorine it seems to drop at a rate of about 2 per day. I am trying to SLAM the pool for a few days to see what my tests show. Had a drop from around 20 to 16-17 few times today and will test again tomorrow morning. Sorry for the long winded post but I wanted to include everything I thought would be pertinent.
Thx
Thx
