Safety Pool Cover Assistance
Mar 27, 2013
53
Newark, DE
I'm not a new pool owner, but I have never dealt with a safety pool cover before. I've been using tarps and water bags for the past 20 years on a sort of oval 16x32 pool, the sort of is the semicircle ends are actually 6 straight edged pieces that are angled to make that semicircle but the angles are not defined enough and since its 6 pieces and not 3 it isn't really a common Grecian pool shape. If I were to break it up into 3 parts, it would end up being a 16' diameter x 8' radius semicircle on each end of the pool and the center section a 16' by 16' square mid section.
Does anyone have a suggestion for a place to get one since its not a true oval, or can I treat it like it is an oval since the angles are subtle enough that it could get by as an oval?
Any thoughts or suggestions before I drop that 800 to 1k on the cover?
TIA,
Brian
If you find an oval cover that covers your entire pool you should be able to use it. Just depends if all the sides of the cover are on the coping or deck and you have anchor points.
