I am just starting to do my own pool maintenance. I have had a major battle with algae this year and in past years. It looks to me like the best solution for my pool is to use Clorox to maintain the proper FC level. Up to this point I have been using chlorine tablets which have caused the CYA to increase to 80. Consequently, I have continued to have an algae problem.
My plan is to decrease the CYA to between 30 & 50 by draining water from the pool. Once I do this, I will shock the pool to get rid of any algae that is present. According to Pool Math the recommended FC level for my pool is 6-8 and the shock level is between 20 & 29. My plan is that I will shock the pool about once a week to prevent the return of algae. My concern is that I have read that it is not safe to enter a pool with the FC level greater than 9. Therefore, I will have to monitor the pool after shocking to allow the FC to drop below 10 before swimming in it - is this correct?
Basic pool facts: 33,000 gallons, Pebble Tec finish, Paramount in-floor water jet circulation system, Sta-Rite cartridge filters, Pent-Air variable speed pump.
I would appreciate any comments/recommendations regarding my plan. Your TFP site has been very helpful and extremely educational. Prior to my association with TFP, I was using test strips and occasionally taking a water sample to a pool store, which always ended up costing a fortune in chemicals. With your help, I look forward to having a Trouble Free Pool. Thanks!
