Hello all,
I have an 18x33 oval pool. Partly sunk in about 2 feet. Pool is 9 years old. I had a leak in the liner last year which led to rust on the side wall. When the liner was replaced, they put foam between the wall and the liner to cushion, I guess. Now the rust has worn all the way through and I can see the foam bulging through. Is is possible that this section could be repaired or maybe reinforced? Does the whole pool need replacing? Taking it out altogether would probably cost a lot due to the 2 foot deep foot print that would need to be filled.
Thanks for any advise
