Hey TFP'ers!
Finally got my RJ60+ installed and running (with a slight replumb to make it all nice!). Pretty great! My final question is looks like the flow switch is sensitive enough to register flow even at very low RPMs on my VS pump. My typical pump schedule is as follows:
1200 rpm - 12hrs (overnight just to keep any critters in the skimmer) - tried dropping down to 900 rpm and it still registered flow!
3200 rpm - 4hrs (morning 'til noon to suck any small rodents/amphibians/small cats into the skimmer and run the Polaris)
2200 rpm - 7hrs (keeps skimmer sucking while we swim)
I don't mind keeping this schedule...still costs very little to run the pump and keeps most critters clear or debris off the surface. I thought the flow switch would kick off the SWG overnight (below 1400rpm) but it still keeps working - so my question is for cell life/equipment preserving...is there a better way to run the SWG? I could easily load the SWG up on a timer - it's technically on a timer now (smart switch for home automation...but it's in a constant on state...merely just measuring energy consumption)...but if it's all the same to run it 24/7 on a very low percentage, then I'm more then fine leaving as is! It looks like 10% right now either holds my FC as is or slightly increases...but we don't have any swimmers and I just opened it all up so I think that is about where it will be in full season. I just didn't know power cycling vs constant running has any effect on anything, or I'm just over thinking all of this
Thanks for all that helped with previous questions and my replumb!
