Rule Pool Cover Pump - electrical reconnect/replace/retool
Ryans19
15
Swisher, IA
Pentair Intellichlor IC-40
Does anyone have experience reconnecting the electrical at the base of the unit? This has been a great pump for me but the connection is not the beat and need to reconnect those wires.
And if not, what newer pumps do you recommend that will last and not clog the water line?
Thanks in advance!
Ryan
Iowa
92395: POOL COVER PUMP
Thermoplastic Construction
FEATURES
2100 GPH @ 0’
Thermoplastic construction with built-in handles for ease of transport and installation
1” NPT discharge
3/4” garden hose adapter
Activates in 1-1/2” of water
Pumps down to 3/4” of water
Large base design for added stability
Bottom screen removes easily for cleaning
Internal automatic vertical float switch
Hermetically sealed, oil cooled motor for long pump life
Clog resistant impeller
Motor is thermally protected with automatic reset thermal protector
Energy efficient split capacitor motor. Lower amp draw, runs cooler, lasts longer
Stainless steel motor shaft
Carbon/ceramic/stainless steel mechanical shaft seal
Upper and lower permanently lubricated ball bearings
Stainless steel fasteners
Acceptable for indoor or outdoor use
Compact, lightweight design is easily portable
Every unit is 100% pressure tested.
