Yesterday I noticed what appears to be a rubber washer spinning around on the shaft of my pool pump between the motor and the impeller housing. Is this normal? I don't know why that would be there unless something is loose in a seal. There is no water dripping but I would like to go ahead and fix this if it could be a future problem. This new pump has only been in service, typically 8 hours per day on low speed, for about a month and a half. It is a Pentair 1 HP 2 speed pump. The pump is not making any noise and still has a very strong flow to the pool even when on low speed. The pump was on when the pictures below were taken. Thanks for any insight.
