Well, I got sidetracked onto other priorities. I did talk to a different person at Pentair that said the cable will not work. In the meantime I am running the pump 24 hours a day, mostly at such a low speed that the iChlor won’t run due to lack of sufficient flow. I’ve used a manual timer before with a different pool. I found that you still need to keep an eye on things after a power outage. When the power comes back on, the pump and the timer controlling the iChlor may be out of sync. I’m planning to go with the current sensing relay. Unfortunately, the one mentioned on this site seems to be no longer available. Hopefully, someone will recommend one that is available and reasonably priced.
