RPM changes from EasyTouch setting
petman
13
Danville/CA
I have the same issue. I have Pentair Screenlogic Pool app from 15 years ago and it has worked flawlessly. Now when I want to change the speed for the "Pool" setting it works fine. When I want to change the speed for the Cleaning setting, it changes and then reverts back 3 seconds later.
P,
Does not sound like something that ScreenLogic or the EasyTouch can do... :scratch:
Are you using your PC or a phone to make changes?
Can you tell me, or show me, what you are doing? Pool vs. cleaner?? In general, all the electronics used to change "Pool" would be used to change "Cleaner" so on the surface it makes no sense, that one would work and the would not work..
Something else must be going on..
We need more info..
I am in the screen logic app on my phone. This is within the speed control portion of the app, not pool or cleaner although they are indirectly affected because the speed set in Pump section tells the pump what speed to run for each of those settings. Here is a screen recording. You can see when I change the speed of the last two, they just revert back and actually change the speed above them. When I change the speed on the Pool setting at the top, it holds, maybe because it doesn't have a setting above it, IDK. Turns out I can't attach a screen recording. but here is a screenshot I have used for many years to change speeds.
Oh, and you can change the speeds with the remote. I believe it is/was called the Mobiletouch. I still have it laying around so I tried that too to no avail.
