The pool is already installed nuklhead. If you read the tread from front to back, you will see what was done. I don't need counseled. Thanks for the offer though. I'm pretty nuts as it is and like it that way.
crek31 said:+1 what Bama said. Last year I had a small drip all season. When I disassembled it to take down the Intex, it was clear the gasket was never on quite right - on one side the installer had missed the pre-drilled holes. This year I made an extra effort to hit all the factory screws and no leak at all. Good luck! It is time for this pool to be a source of rest and relaxation for you guys!!
Casey said:crek31 said:So he was floating on the turtle today kicking his feet around the pool.![]()
Hang in there girl. It's so nice to hear you've got the pool up.Casey said:Wish I could have been here to see it!
So, I fired the pump up n have a leak in the return fitting. I'm running it for a bit to circulate my chlorine for a bit n then I'll hammer it out tomorrow. I may have missed a part that needs Teflon tape. I don't know... ugh
