Roman concrete … should we do hot pours?
JoyfulNoise
Platinum Supporter
May 23, 2015
25,764
Tucson, AZ
Pentair Intellichlor IC-60
Now this is some fun science -
I’m a big fan of going back to adding pozzolans and asbestos to all my concrete work!! And now I just need to get a rig setup to do “hot pours”!! If it’s good enough for the Romans, then it’s good enough for me … plus I think I look pretty good in a tunic 😉
Animal House Quote GIF by Top 100 Movie Quotes of All Time
--Jeff
Fly ash (a pozzolan) is a common admixture. In fact the base mix in the study used fly ash.: OPC, pulverized fly ash, sand, and water at a mass mixing ratio of 1:0.2:2:1 with between 7.5% to 15% by mass of quicklime (so you can mix up your own). It does get pretty hot. The temperature increase in the mortar is approximately 55° to 60°C over ambient, with a presence of hot spots characterized by temperatures exceeding 200°C
It appears it is a combination of the quicklime and the high temperatures that form the lime clasts that are responsible for supplying the calcium to react with the pozzolanic material to self heal cracks.
That was a really cool experiment. Reinforced concrete lab was one of my favorites, where else could you mix gantry cranes and steel work with chemistry (and then breaking things in hydraulic presses)
Reactions: JoyfulNoise
Not sure what you do Joyful, but good on you giving a rip to make something last.
I discovered the view of my pool builder was pools are likes cars these days, 10 years and its time to upgrade. I was hoping for at least 20 to 30 years. Don't think I'm moving.
For the record, self healing concrete has been around for a decade, if not more. It has to with the inclusion of various admixtures - mainly fly ash and silica fume and then grinding everything up into a fine powered using specialized mills. High Mixing Energy Concrete. Basically you beat the every lovin' daylights out of the cement mix before you add water.
However, as to how the Romans did it was previously a mystery. Apparently they just added unslaked lime, which caused high temperature areas that form lime clasts. The interesting thing is, that people knew High Mixing Energy works, and they have been reporting that it creates high temperature hot spots in the mix as well. Now somebody put two and two together.
Reactions: Jaffles
