rajung
I have had my PB Max vac for 5 years and still works great but I do maintain it every time I use it, such as to make sure it is out in the sun to dry laying in different angles to make sure any water caught gets drained the best it can. Also the lithium battery change was due to the fact they weren't available when I purchased mine originally with the standard NiCad, but it still worked.
The smaller vacs might be good for kiddie pools or spas such as the ones at Menards.
The Blaster for main source of cleaning would be a real challenge, depending on how much needs cleaned out.
You would be changing/ cleaning the bag a lot.
And most likely the battery would be drained dead in a large pool.
Just my opinion, but I would say the pool blaster max and up from there, anything smaller I would not mess with, better off going the skimmer port and hose vac routine.
So my best opinion for your situation, I would skip the vac to skimmer option, get the Dolphin E10, and hold off on the vac on a pole, get a good test kit, a couple brushes different sized if needed, and brush once a week.
If you decide to get the Dolphin and have a lot of fine dirt that you have to deal with like I do and did, since I don't get many leaves, get the extra ultra fine basket also, its 60.00 but way worth it, my Aquabot pool rover I originally bought even with fine bags could not compare to the Dolphin, Good for leaves and larger things but that's it.
