Robot doesn’t move - Pentair Warrior SI
Apr 27, 2017
103
Miami FL
Robot control panel turns on.
Robot itself doesn’t move at all under water most of the times I turn it on. Some (fewer) times works fine.
I checked the impeller for obstructions, cleaned out some leafs there, tried again and no movement.
I turned the robot upside down outside the water, tried three times, one time it moved.
What additional troubleshooting can I do?? Any additional suggestions?
Thank you.
Well, after posting, searched the forum.. and it looks like I bought a Robot that many ppl is having issues with… :confused: … a 2020-ish model…
I have a SE I bought early in 2020 haven’t had any issues. Does the power supply lights stay on?
There have been a few folks in here that have had motor failure and it’s not a cheap fox. Did that reason some has decided to go back the old style suction cleaners
