RJ45 SALINITY READING
wicamppool
45
Wi
CircuPool RJ-45
It is now up to 2900 seems to be making chlorine still has low salt light on.
Is the salinity reading increasing?
Can you stir the bottom up a lot?
You need a good salinity test kit or meter.
Can you recommended a good meter? Like something easy that employees can check.
JonoVegas
77
Las Vegas NV
I have an RJ45 for a little over 1 year and I love it!!!!
Yes the salt readings on the RJ45 will confuse the heck out of you when you are starting out with the RJ45. Bottom line, use the Taylor salt test kit when you are starting out with your RJ45. Should you be able to rely on the RJ45 salt readings initially? Yeah sure, but get over it. I have found that after several months I can now rely on the RJ45 "salt" readings. Again I bought the RJ45 to generate chlorine not to be my salt tester and it works beautifully generating CL in an unattended mode, again love the RJ45. The Taylor salt kit is inexpensive and works. You only need to test your salt levels initially (first couple of weeks). Once stable the salt level really won't change much under normal conditions so you won't be measuring the salt (only to put your mind at ease periodically).
wicamppool
45
Wi
CircuPool RJ-45
Thanks for the info. It took several days for the RJ45 to be happy with salt level even though numbers did not change a lot. Also amps on cell now show positive 4.09 or so....
wicamppool
45
Wi
CircuPool RJ-45
Noticed tonight this rust color at end of cell is this normal?
JamesW
28,291
Dissolve some vitamin C tablets in a quart of water and then remove the cell and pour in the water to see if the brown disappears.
If it does, it's probably iron.
Rinse well and reinstall.
wicamppool
45
Wi
CircuPool RJ-45
Probably iron.
I would get an iron test kit to see how much iron is in the water.
Did the cell get dropped?
It looks like it might have a crack?
No I think you are seeing a little piece of grass. Saw that too had to look twice.
Will that hurt if its iron? Is there a e at to control it?
wicamppool
45
Wi
CircuPool RJ-45
# 1 looks like an impact.
# 2 looks like a crack.
The cell is after the filter. So, no grass or other debris should be getting to the cell.
No its grass and debris. I wondered about why its getting past the sand fiter.
Maybe I need more sand in the filter? Sorry really new to this. The filter is about 1/2 to 3/4 full with pool filter sand.
