RJ 45 installed
MA5177
216
Phoenix, AZ
CircuPool RJ-45
Got my RJ 45 installed and working today, it’s generating chlorine just fine at 60 deg water.
It’s 3x oversized so I am going to start off at 10% since I am running the pump 17 hours a day at 1500 rpm and see where that takes me
Reactions: MA5177
what are the thoughts on the cell, hump up or down, as the circupool manual shows both ways, would not hump down help keep the air bubbles from forming and keep the plates well submerged?
It looks like that would yield u about 1.4ppm of fc - which may be enough to maintain in cold, less sunny conditions but it will definitely need to be monitored & increased as the season progresses in sunny 🌞 hot Phoenix.
0BEA5A70-2539-4662-B9C0-89F5B5DDF812.png Great job on getting it in!
Reactions: MA5177
View attachment 392889 Great job on getting it in!
My pool is 12,500 gallons, this is a 45k gallon. I’m sure I am good for now , as the weather warms up I will be raising it as needed thanks
Reactions: Mdragger88
I have a single speed pump and should not have a bubble issue, but the tinkering side of me says its seems much better to just run it with the dip, so down it stays.
They recommended hump down for very low RPM , I can spin it over but it will be against the pipe below it. It’s doing just fine at 1500 rpm no bubbles and I can see the “clouds” when it’s generating this way.
