- May 3, 2007
- 18,073
- Plaster
- Hayward Aqua Rite (T-15)
As stated above, you don't need one before the SWG and you don't need one on the solar supply (or second return) side if you remove the bypass. The bypass isn't really needed if you use the solar valve as a bypass as well. If actuated, you can adjust the cams to any position you need.Thought I'd read that there should be one before the SWG. Had questioned the value of check valve above it myself. Probably misinterpreted something when I figured out that I was going to need a Solar 3-way (solar on/off) AND a Solar flow control (low pump speed/high pump speed if in-pool spa-type jets mode).
