We have a pool - spa combo with spillover dam. During SPA usage we use valves to suck water from the bottom of the SPA through 2 x 2" drains, through Pentair 1.65 HP pump through Hayward S244S sand filter and the through Jandy Lite 2 heater and currently return through single 2" return located in SPA. Current there are 6 x 1" SPA jets with 1/2" venturi vents located just above each jet. The plumbing was initially setup with one 2" line feeding 2 x 1" jets and another 2" line feeding 4 x 1" jets. My question is with the filter and heater inline with the pump output, will the current pump drive all 6 jets or would I need a booster pump to get good spa operation. One option would be just to plumb the either of the existing lines...the 2 jet or the 4 jet and run it that way. Feedback requested...
